Threads: 4
Thanks Received: 1 in 1 posts
Thanks Given: 6
Good evening all I've got a 2012 1.6 hdi At 93000 on clock fan would not switch off so changed coolant temp sensor that sorted it,at 97000 had cam belt and water pump changed but fan will not go off for love nor money so had temp sensor changed again and the fan relay but still it stays on I use it daily at
least 80 miles a day so not many short journeys any ideas please ?Tia
Threads: 75
Thanks Given: 223
164
Worth trying a battery disconnect for 10 mins and see if it resets itself. Does the temp guage read properly?
• Digger1326
Threads: 75
Thanks Given: 223
164
Does the gauge always read that value as soon as you turn on the ignition, or does it seem to reflect the proper engine temperature when cold? Trying to figure out if the CTS is actually working
• Digger1326
Threads: 75
Thanks Given: 223
164
ok cool, so weirdly it can't be the CTS triggering the fan, and the fan comes on with ignition now? I'd be wondering about the fan control relay or a fault on the ECU but you tried the relay so can't be that.
My thoughts are:
1. Do a BSI reset. Battery disconnect may fix it anyway but if not do a full BSI reset and see what happens.
2. Check you have no water ingress into the BSI
3. Check and clean the ECU plugs and refit them. Use alcohol cleaner or switch cleaner, not wd40 or anything like it
• Digger1326
Threads: 123
Thanks Given: 250
34
The fan will be on when the aircon is on. Just a thought.
