11-06-2020, 09:53 AM
Hello
Yesterday drove my 2010 M59 1.6HDI all day with AC on and it worked good. On steep hills im shutting down the AC compressor pressing the AC button on the tash to help the small 75hp climb up and turning it back on after iv passed it.
The AC button and AC system worked fine all day on 30c+ outside , but in the evening on the way home (about 26-7c outside) at some point iv tried to turn on the AC again but the button wont react and wont light up the small yellow light that shows the compressor is engaged. pressed it few times until i got home and nothing - the button wont light up and the AC compressor wont engaged.
Today i went to start looking for the issue on the system, first thing i did was starting the car and turn on the AC system and now it works fine again as it should. pressing on the AC button turns on the compressor and cold air is getting in.
At no point the car overheated - my temp gauge sits very steady on 1 line under the middle point (90) and gets there very rarely.
I dont want it to happen again as it will probably will at the least comfortable situation, so im asking what could be the cause for this issue?
