Threads: 4
hi all
I have a berlingo xtr 2015
the earlier b9 had a boot torch fitted, i have a torch to fit i know were the cut out to fit it but is the wiring still there
i know there was a reply on here about 4years ago but can not trace it.
thank you all
Threads: 75
Thanks Given: 223
164
Without being too obvious, you'd want to take the panel off to cut the blank out, so you don't hit anything your not supposed to, so when that panel is off, you'll see the wiring? No wiring, no need to cut the panel out.
Threads: 54
Thanks Received: 81 in 75 posts
Thanks Given: 147
7
I've got a 2016 XTR without the torch, please let us know what you find as I was thinking about this mod too, I've missed not having the torch as I had one on my previous (2010) XTR
Matt
previous
2016 1.6 HDi 100 XTR Grey Met
2010 1.6 HDi 105 XTR Gold Met
Threads: 29
Thanks Received: 12 in 9 posts
Thanks Given: 17
In my Berlingo I have a small rechargeable torch with a usb end, (eBay purchase).
I simply have the torch plugged into a usb socket which is fitted into the 12v socket.
Thanks to the dark rear windows the torch is invisible from outside.
