Electric handbrake rear brake pad
Hi there how easy is it to change the rear brake pads with electronic parking brake ? Can someone steer me into the correct procedures
We have not encountered this system yet on a Berlingo, but I assume it will be the same as a C4 Picasso etc.
If the park brake motor is on the Caliper itself, then you need a diagnostic tool to set the callipers in release mode, then simply squeeze the pistons back.
After fitting the pads, pump the pedal & reset everything on the diag machine.
Without diag it is not possible to do this job.
If it is the same system as the C4 Picasso the video in the link shows how to do it with no diagnostic tool, you just remove the motor from the caliper which then allows you to rewind the piston.
https://www.youtube.com/watch?v=aS-yHISlyaQ
(02-07-2020, 07:04 PM)jj9 Wrote:  If it is the same system as the C4 Picasso the video in the link shows how to do it with no diagnostic tool, you just remove the motor from the caliper which then allows you to rewind the piston.
I would definitely not do this. They can be tricky to set up with diag , let alone removing the motors.
VW have been using this system for years & they fail all the time for water getting into the motors, the last thing you should do is risk this for the sale of not having the correct diagnostic tools.
(02-07-2020, 07:11 PM)Lighty Wrote:  I would definitely not do this. They can be tricky to set up with diag , let alone removing the motors.
I though when using a diagnostic tool you just put the handbrake into service mode (or whatever it's called) and then fitted the new pads, then exited service mode. . .  is there more to it than that?
One of the reasons VW's had problems with water getting into the motors was because the plastic case of the motor was developing cracks, not sure if they have addressed this now.
The VW lads have been removing the motors from the calipers to fit new pads for years without problems, if the motor is replaced correctly it will be as good as it was before you removed it.
M59 1.4 Petrol question
Last Post: Gadgetman
Today 01:30 PM
Cold Starting
Last Post: jboy012000
Today 10:46 AM
Yesterday 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
