Threads: 31
Thanks Given: 18
Anyone on here have the wiring diagram for the rear lights of a 09 hdi?
I have the lights fitted and all the grounds fixed but I can’t find which wire is the one for the parking lights at the back. Once I know which wire or PIN number I can connect them up. Bought one of those pen voltmeters but it’s useless
Threads: 75
Thanks Received: 1,308 in 1,140 posts
Thanks Given: 223
164
24-06-2020, 11:34 PM
(This post was last modified: 24-06-2020, 11:35 PM by Sol.)
What lights? You seem to assume we know what you're taking about ?
Threads: 31
Thanks Given: 18
Which wire is for which bulb in the back lights. There is 6 wires in the connector that clips into the bulb holder for the back lights and I need to know which one is the parking lights wire
Threads: 75
Thanks Given: 223
164
Pen volt checkers are for mains AC electricity. They don't work on 12v DC.
Get a proper meter with leads and a digital display, then put it on DC volts, touch the black probe to the bare metal bolt the tail light fixes on with, and with the red lead probe all pins on the plug, one at a time, with the sidelights on....the one with 12v on it, is your wire.
Threads: 10
Thanks Received: 12 in 11 posts
Thanks Given: 3
Hi Lively have a look for towbar wiring theres a not of which couore is what I think the side lights might be gray ..
Jake
