[Filters & Oil] Oil sump drain plug
Hi, I'm soon going to give my 2016 BlueHDI multispace a service, I have the oil and filter, but not sure what sump plug I will need to replace the existing, any ideas?
Just reuse the old one .....
With a new washer.
Or if you don't have a new washer due to not knowing the correct size (M10?) you can re-use the old one with a little silicone instant gasket. If possible anneal the old washer over a gas flame until cherry red, quench it in water to get most of the crud off, then a light wire brush.
(26-06-2020, 03:31 PM)cancunia Wrote:  Or if you don't have a new washer due to not knowing the correct size (M10?) you can re-use the old one with a little silicone instant gasket. If possible anneal the old washer over a gas flame until cherry red, quench it in water to get most of the crud off, then a light wire brush.
Thanks, yes I wasn't sure on the size of plug/washer I'd need and thought for the sake of a couple of £s I'd just get new ones.  M10 has pointed me in the right direction, that seems to be it.
Other than when undertaking a full engine or gearbox rebuild where I've had a full gasket etc kit I've never changed a sump washer let alone annealed one ...... leak what leak !
edit : ^^^ 50 years of such leak free activity  Heart
(26-06-2020, 06:01 PM)geoff Wrote:  Other than when undertaking a full engine or gearbox rebuild where I've had a full gasket etc kit I've never changed a sump washer let alone annealed one ...... leak what leak !
Smile Although I can only claim 40 years of leak free activity, I still like to be sure so normally apply a bit of belt n braces as it's a bit embarrassing to have to take a drain plug out when you've just put in fresh oil.
It's difficult to anneal plastic washers as fitted to another engine I have & I always forget to buy new ones, so a bit of instant gasket has never hurt.
Plastic yikes ... which car ??
(27-06-2020, 09:16 AM)geoff Wrote:  Plastic yikes ... which car ??
I think it's on a 1995 Ducati engine, now sold. But I'm sure I've seen others in the past too.
  • geoff
It’s definitely a good idea to change the washer on your sump plug, the Blue hid engine uses 0/30 oil, which is very thin & finds the slightest flaw.
The 2.0 Euro 6 engine in the 308 etc uses a plastic sump plug that is held in with a small split pin for safety’s sake.
It is recommended to change the whole plug on these, think they are about £10 from psa.
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
