Threads: 4
Thanks Given: 10
Hi, I'm thinking of buying a 2008-2018 Berlingo which will be my daily driver but also for the odd overnight stay. I've looked at a few boot jumps but I can't work out what happens with the rear seats. Do you have to remove them entirely before you set off? Or can you just fold them forward when you want to sleep?
Also, if they fold forward, do they fold completely flat? And what about the front seats, will these fold flat too?
Thanks!
Threads: 2
Thanks Received: 2 in 2 posts
Thanks Given: 7
I own 2005 and rear seats have to fold to fit boot jump. They are not flat. Newer models not sure but for boot jump or similar they don't have to be flat.
Hope it helps
Sent from my ONE A2003 using Tapatalk
The following 1 user says Thank You to OrtesPL for this post:1 user says Thank You to OrtesPL for this post
• DaveS
Threads: 4
Thanks Given: 10
Great thanks. Folding totally flat isn't a deal breaker. Glad they they don't have to come out every time though.
Anyone with a 2008-2018 know if they fold flat?
Threads: 4
Thanks Given: 10
Cheers! Is there a way to tell which is which from the year or variant name or do I have to check if I go and look?
Threads: 47
Thanks Received: 71 in 65 posts
Thanks Given: 121
7
28-06-2020, 06:59 PM
(This post was last modified: 28-06-2020, 06:59 PM by Matt Haigh.)
AFAIK All the B9 XTR's have 3 individual rear seats, I'm not sure about the other trim levels/options
Matt
2019 Multispace BlueHDi 100 Flair Nimbus Grey Met
Threads: 4
Thanks Received: 10 in 9 posts
Thanks Given: 1
I have a 2021 B9 Plus trim model and it has the double and single rear seats - they both come out ok though when necessary.
Threads: 4
Thanks Given: 10
Cheers Cliffy, do they fold flat?
Any idea if they are OK with boot jump?
I'm not sure how important the 3 seats are vs the 2/1. Not sure if I should be ruling out the 2/1s or not
Threads: 7
Thanks Received: 32 in 28 posts
Thanks Given: 5
look on here.........Finished Boot jump...posted by Snels
