01-07-2020, 06:58 PM
Hi Guys,
I've clocked up 30k miles in the car now will very little problem, not bad at all seeing its done 120k miles. Up until now. I think the gearbox has had it.
For a little while occasionally it had a problem in 2nd gear. It would go into gear but would not engage the drive, just spun gear wheels around. All other gears were fine and the clutch operated fine. The problem in 2nd gradually became worse and noticed that it only did it when changing into 2nd going up hill. Then it changed and is stuck in first. Clutch still works to disengage the drive. I can move the gearstick forwards and backwards only (1st and 2nd gear positions) but has no effect of moving it out of 1st. I thought/hoped that it might be a problem with the linkages, but after removing battery etc to view there doesn't seem to be a problem with the linkages.
So I'm probably looking at another gearbox. The existing one is marked 20DP47 but all of the second hand units found on the internet have high mileage. Would gearbox 20DP48 fit as they are newer available with less mileage? Or another newer version?
Regards
2009 XTR 1.6 HDI
Regards
2009 XTR 1.6 HDI
