Threads: 3
Thanks Given: 2
Hi all
I have a 2009 B9 Berlingo with the tu5jp4 1.6 petrol engine and need to do the cam belt on it. Does anyone know the size of the torx head bolts on the engine mount? Also are they normal torx or torx plus? I need to go socket shopping.
Cheers
Reesespieces.
Threads: 123
Thanks Given: 250
34
Have you tried normal hex sockets on the bolts?
Threads: 75
Thanks Received: 1,299 in 1,139 posts
Thanks Given: 223
163
They're e-torx and Halfords sell them singly or in sets mate. Like a star head?
Threads: 123
Thanks Given: 250
34
I can't remember exactly & can't check as I've sold my B9, but are the Torx head bolts actually studs screwed into the engine mount casting & then use a hex nut onto that stud to hold the mount to the engine?
If so, you'll be able to get away with normal sockets to hold the stud in place as the reason for the Torx head is to allow a nut over the top of the stud.
