24-12-2011, 02:21 PM
(This post was last modified: 24-12-2011, 07:40 PM by RocketVANman.)
After having just serviced my wifes' Pug 307 (also a 1.6Hdi unit), I decided to have a quick look/comparison with things against my new Berloingo Van.
Good points: There definately seems to be lots more room to change air filter with out having to spend ages removing numerous parts. I recon I could do it in ten minutes. There also seems to be much more room at the front to access the turbo and could do an oil change very easily.
That's good as I intend to do oil changes every 6k miles in between the garage services until the warranty ends then I'll do them all.
Belly Pan/Guard - Looking underneath there does not appear to be a belly pan at all. The bottom of the engine is in full view. Obviously that makes it very easy access for but surely there should be a belly pan?? Or not??
Yours confused
That's good as I intend to do oil changes every 6k miles in between the garage services until the warranty ends then I'll do them all.Belly Pan/Guard - Looking underneath there does not appear to be a belly pan at all. The bottom of the engine is in full view. Obviously that makes it very easy access for but surely there should be a belly pan?? Or not??
Yours confused
unny:
