B9 decat
Hi all.
Just gutted out the DPF on my van (hole saw and a hammer btw, no cutting or welding reqd) and while I’m here I was thinking of doing the Cat too.... now, I know it won’t pass an MOT but I use it solely on private roads and therefore don’t need an MOT....
But what else will break after I do this?
I am aware it may need a remap and will likely throw a wobbly and go into limp mode also.... nothing new there then.
It’s a 1.6 model
Cheers
You may need a resistor on the DPF sensor to fake the difference in pressure from inlet to outlet of the DPF. Why take out the CAT, it won't make any real difference to the exhaust flow?
Yesterday 02:32 PM
Berlingo 2026
Last Post: xtimex
Yesterday 05:06 AM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
Weird Air in Fuel Problem
Last Post: tomhick024
27-06-2026 03:25 PM
