Second USB Socket
Hi,
I have just collected my brand new Berlingo Flair XTR and I'm trying to understand the USB connections.  I appear to only have one; found in the corner of the touch screen.
In other models in dealerships there was a second USB in the Glovebox - mine just has a blank; the manual says there should be one at the back of the centre console, but there isn't one (no blank, I'm not sure there is space)
So the question is:  Can I knock out the glovebox blank and fit a second socket (and maybe AUX Jack).  It looks like removing the glovebox would be easy; but what part would I get, and where would it connect?
Second question, assuming the first is 'yes', is it possible to swap the functions of the 2 USB's over?  I would really like my iPhone connected for CarPlay via a concealed cable, which the USB in the screen doesn't lend itself to.
Many thanks!
Ben.
I’d also like to know this - I was surprised to find a blank in the glove box too..!
afraid the one in the glovebox doesn't work for carplay - i am not even sure what it works for as i cant even charge a phone off of mine.
Has anyone found a solution for this glovebox aux/usb socket ?
On a Fakra connector, which the Berlingo stereo uses, there are pins for cd changer in and other stuff, I expect you can buy an aftermarket cable that plugs into the rear of the Fakra and adds a usb input, if you don't already have one usb plus one aux, as there is only a selection in the head unit for usb / aux / phone / radio / cd and adding an extra input would either have to pretend it was one of these or act as if it was a changer (like the connects2 adaptors for BTZ do) so you could use it.
Citroen actually say not to plug a device into the usb and aux at the same time but not sure how the double usb copes, I only have one usb too.
EDIT: found the Citroen quadlock Fakra pinout, see aux 2 etc:
https://pinoutguide.com/Car-Stereo-Peuge...nout.shtml
Here is a commercial add on as I described above, with usb and other inputs:
https://www.car-interface.com/vendita/en...rlink.html
  • hc98br
(22-11-2020, 08:16 AM)Zion Wrote:  On a Fakra connector, which the Berlingo stereo uses, there are pins for cd changer in and other stuff, I expect you can buy an aftermarket cable that plugs into the rear of the Fakra and adds a usb input, if you don't already have one usb plus one aux, as there is only a selection in the head unit for usb / aux / phone / radio / cd and adding an extra input would either have to pretend it was one of these or act as if it was a changer (like the connects2 adaptors for BTZ do) so you could use it.
Thank you for the info Zion, very useful stuff.
[-] The following 1 user says Thank You to Paul_C for this post:
  • Sol
i got a driver and there is usb in glovebox the boy only uses it to charge his forever flat phone but i dont use the 1 on the front of radio much
Thanks @Zion, really useful info.
One other question; do you know of any guides/videos that show how to remove the stereo (and get at the ports)?  I had a quick go, but chickened out of using too much force!
Many thanks!
Ben
Bought another Berlingo today, there's no USB in the glove box. I need to add it at some time. Is it doable?
ex: 2003 1.4i cargo
Today 08:33 AM
Not able to register
Last Post: Mike
Today 01:38 AM
Yesterday 10:15 PM
2011 B9 DPF warning light
Last Post: IKUN
Yesterday 03:30 PM
M59 rear wheel splay...
Yesterday 03:27 PM
Indicator/lights Stalk
Last Post: magoo1
Yesterday 03:09 PM
Last Post: pondweed
Yesterday 01:21 PM
Yesterday 12:41 PM
Yesterday 09:18 AM
» Replies: 23
Free To Collect From CO14 8LD B9/K9 Floor Mats
Last Post: Matt Haigh
Yesterday 12:43 AM
