[Filters & Oil] Please help
Hi, I have a berlingo 1.6 HDI. It was registered in 2011 however I believe this is the older model ?
The question is, where is the cabin filter located ?
I have looked on you tube and thought it was on the drivers side, however after dismantling it I could not find anything.
My little lad often comes for a ride in the van, so I was trying to lessen the pollen entering the cab as he suffers with hay fever.
Any advice welcome
Cooksey
They only have a pollen filter if you have AC.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Thank you so much, that’s solved that.
Maybe treating the car's air blowing system, seats, and carpets might help a bit. Search the web for 'air con bomb' - these are aerosol cans containing stuff that will sterilise an enclosed space, such as a car with closed windows. They are aimed at air con systems of course, but the basic idea is that once the nozzle is pressed in the can sprays continuously until it gets empty, and if you leave it like that inside a car with the blower blowing at full speed for about 10 mins then the spray's effect can get into every nook and cranny. Therefore it may also work in cars without ac - but over to you to verify that.
One point - they are mostly scented, which is a problem for me as I am mildly allergic to artificial fragrances, so some research on that area might be useful.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
I should have added: with engine running to avoid flattening the batt, with the nozzle pointed at an air intake (front footwell), and with air system on recirculation mode.
53 1.4i MS MPV RIP
08 C4GP 1.9 VTR+
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
