  • 12 Vote(s) - 2.42 Average
Bush under engine
Hi all,
Could anyone identify this rubber bush under the engine? There are two, one on both sides. Mine need replacing and I'm not sure of the part name.
Cheers,
Jay
[Image: 2co04r8.jpg]
Does this attach to the bottom of the stub??
Think they may be known as a "P" bush in the trade on account of the shape, sorry but I don't know the actual techie description
Rear wishbone bush looks like
(26-12-2011, 11:13 AM)misterjk Wrote:  Hi all,
Cheers,
Jay
Hi. Without VIN we can't help you.
(26-12-2011, 01:52 PM)800HDI Wrote:  Rear wishbone bush looks like
Yep
Does looke like wishbone mounts in my previous experiences it easier swapping them with poly bushes some fine it easier replacing the whole wishbone as the bushes are a pig to remove!
To remove the bush once the wishbone is off the car destroy the rubber part (you could use a blowlamp) and then use an angle grinder on the metal sleeve until it starts to split (be careful not to go right through and mark the pin). Press a new one on making sure that you have the alignment right. (My press was a lump hammer)
Peter
Many thanks everyone. Replacing the wishbone today.
(27-12-2011, 12:35 PM)Neds Wrote:  Does looke like wishbone mounts in my previous experiences it easier swapping them with poly bushes some fine it easier replacing the whole wishbone as the bushes are a pig to remove!
Can you please tell us where to obtain the polybushes from???
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
