Threads: 69
Thanks Received: 22 in 22 posts
Thanks Given: 7
4
Hi all u all ok ? anyway i was driving my lingo yesterday and all was ok !! got in it today and it wouldn't start ,turns over but it wouldn't fire up ! called out mechanic from my local garage ,he put a meter on it and said there's no power going to glow plugs and couldn't see to it end of next week (bummer) has any one got any answers??? thanks in advance. Gwyn
nice to be important,more important to be nice
my ride is a berlingo forte 1.9d 2003 model in pukey blue
Threads: 75
Thanks Given: 223
164
17-07-2020, 02:49 PM
(This post was last modified: 17-07-2020, 02:51 PM by Sol.)
It should start with no GP's just now mate, they will only be used at very low temperatures and for post-glow once started for emission reasons. So the likelihood is, that isn't your problem and they are not meant to be on.
The HDi will start without them - unless you don't have the HDi - you didn't say what engine you have.
Could be no fuel pressure, Immobiliser, Fuel shut-off valve, HP Pump, air in the system, fuel pressure sender faulty....the list goes on buddy and testing the GP's with a meter is only valid in cold weather, or after starting (JJ9 will attest to this)
My own thoughts, if you have no EML on and no Immo warning (flashing Key I think) is the Crank Sensor, or a fault in the fuel circuit as above. Do you not have DiagBox?
Threads: 69
Thanks Given: 7
4
Many thanks zion for replying !! it's an 03 1.9d berlingo forte, the only thing i know about cars is changing a wheel and putting fuel in !! the mechanic had it going by squirting something down the air intake while i turned the key !!it fired up straight away
Threads: 75
Thanks Given: 223
164
Ahhhh 1.9D....he will have squirted Bradex Easy Start....
Ok you have a non HDi engine that does need glowplugs. My apologies! You could need a GP relay, or a fuse, (40A) or a wiring repair if no power is going to your glow plugs.
Threads: 69
Thanks Given: 7
4
Cheers zion many thanks ,out of the 3 solutions i can check the fuse !! if i can find the fuse box !! the other 2 I'll have to leave to the mechanic ,i will post outcome !! once again many thanks
Thanks Given: 188
23
I think from memory the glow plug relay is on the nearside wing near the headlight. If you find it get someone to turn the key while you touch it and you may feel it click.
Are we there yet?????
Threads: 69
Thanks Given: 7
4
hello tomcat u ok ?so if it clicks does that mean it's ok ? or kaput ?? many thanks tomcat
Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
my mucker,
Please put your vehicle details in your signature, it would of got you the correct info a lot earlier!
Threads: 69
Thanks Given: 7
4
Ok will do ,i generally put them in the post ,just slipped my mind !! at 73 I'm forgetting everything !!
