Just got a Berlingo enterprise 2017 and use it for business in the week but had the idea to use it as a getaway from time to time.
As it's used primarily for business I need a bed solution that is removable and doesn't take ages to set up and pack away each time.
I also would need it to fit through a hatch into the attic for when it isn't being used as I don't have a garage and don't have a big house
Threads: 123
Thanks Given: 250
34
How about an inflatable or a folding bed? Seriously, you can get some quite good inflatables these days. If it needs a mains voltage pump, simply get an inverter.
Threads: 2
Thanks Received: 25 in 24 posts
Thanks Given: 27
5
(19-07-2020, 07:10 AM)cancunia Wrote: How about an inflatable or a folding bed? Seriously, you can get some quite good inflatables these days. If it needs a mains voltage pump, simply get an inverter.
I am inclined to agree with Cancunia, if you want the ultimate in packability a inflatable bed would be the way to go.
I've camped on a closed cell self inflating mattress many times over the years and even on hard ground they are surprisingly comfortable.
It would, at the very least, be a cheap way for you to test whether your vehicle is going to be suited to sleeping in You can always upgrade as time goes on and you gain a better idea of what you might need or want.
Really useful boxes advertise that they can take a persons weight so if your worried about storage a few of these with a mattress on top might offer a flexible solution.
2013 Berlingo Multispace Plus 1.6 HDI
Threads: 0
I've got a Berlingo van I use as a micro camper and it is fitted with an old folding bed which I've altered to fold up against the side panel. But before I fixed it to the side I just threw it in the van and as long as the passenger seat was down worked fine. Now that I have altered the bed by taking the hinge out of the middle, it is 5 inches shorter and fixed to the side can be used with the seat upright and folds flat so the rear is not affected. But airbed will be easy, cheap and comfortable and would fit under the passenger seat.
