Intermittent brakes staying on
Threads: 22
Thanks Received: 11 in 10 posts
Thanks Given: 2
Hi All,
I have a 2006 Peugeot Partner Combi, 2.0 HDI. Have had some strange occurrences with the brakes recently, and have searched the forum with some reporting similar but not located a clear solution.
My wife works for the NHS and relies on the vehicle - braking issues/risk of being stranded are very worrying. Especially since the AA will due to Covid only recover a vehicle not the occupant.
Initial problem was what appeared to be a seized nsf calliper. Duly replaced, and seemed fine.
Fortnight later it appeared both brakes were stuck on.
Once everything cooled down, system seemed normal.
As a 'no brainer' and affordable fix, replaced both front brake hoses. carefully flushed and and re-bled whole system.
Unable to replicate fault, so far.
But, as appeared after the calliper replacement, first time, all seems fine - but no way of telling if there is an underlying fault - and if so, is still present.
We live in a rural location - and I'm worried about her getting stuck in a vulnerable position as happened last time.
I've spoken to dealers but I am not convinced that they wont simply start swapping expensive components to "see what happens" (eg abs unit, m/cyl. / servo)....which, without being sure which it is is simply unaffordable.
Has anyone had this problem - and managed to solve it?
And/or performed any reliable tests to isolate/prove the faulty component?
I live near Worthing, Sussex - apart from the main dealers (unaffordable) would anyone know of an experienced expert within reach who could help please?
many thanks.
Threads: 123
Thanks Given: 250
34
Welcome to the forum.
So far as you know, is it all 4 wheels that are getting locked or just the front pair or just one wheel?
Threads: 42
Thanks Received: 409 in 366 posts
Thanks Given: 137
31
had a vw passat that suffered now and again from brakes sticking on which needed a new master cylinder.
A towbar fitted to a transit caused the brakes to stick on , the brake light switch was too tight to the pedal and not letting the fluid return completely.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 22
Thanks Given: 2
(29-07-2020, 01:16 PM)cancunia Wrote: Welcome to the forum.
Hi
initial experience was just nsf (hence changing the calliper) . AA diagnosis the next occurence was both fronts. Dont believe it has affected the rears.
thanks.
Threads: 123
Thanks Given: 250
34
I can't remember the braking pipes from the ABS to the front & back but am guessing that all 4 wheels are controlled individually via the ABS system. Have you tried an OBD fault code reader to see if there are any ABS faults?
Threads: 22
Thanks Given: 2
(30-07-2020, 07:14 AM)cancunia Wrote: I can't remember the braking pipes from the ABS to the front & back but am guessing that all 4 wheels are controlled individually via the ABS system. Have you tried an OBD fault code reader to see if there are any ABS faults?
Thanks. I have tried a cheap "DIY" one...nothing, and am waiting to get access to a Snap-On reader which has previously shown codes the DIY has not with prior problems.
Threads: 2
Thanks Received: 25 in 24 posts
Thanks Given: 27
5
(29-07-2020, 11:58 AM)Robho Wrote: Hi All,
many thanks.
Ahh Worthing. You are pretty close to me then! I'm sorry I can be more help with regards to a Citroen "expert" but I do know a mechanic in near Eastbourne who I trust, has always been fair, has advanced diagnostics and has solved every problem I've given him over the years.
Just shoot me a P.M if you need his details, he charges the standard rate for labour but I trust he won't spend your money on guesses.
Either way nice to hear from someone nearby on here, shame it's not good news though.
2013 Berlingo Multispace Plus 1.6 HDI
Threads: 22
Thanks Given: 2
Thanks. Appreciate the offer, and am in the fortunate position of having good local support ...I was really wondering if I might find an "expert" with very specific expertise/experience who has seen/diagnosed/fixed this issue before. Perhaps hoping for the Holy Grail!
thanks again
MOT Emissions repeated fail
Yesterday 05:05 PM
Rear door filling with water
Last Post: Marsaday
Yesterday 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
