[Transmission] Oil Leaking from bell housing
New here & first posting / Ref: BERLINGO L1 DIESEL - 1.6 HDi 625Kg XTR+ 90ps
Driving along i heard a slight "pop sound" then could start to smell gearbox oil  Rolleyes
Pulled over & there was a gear oil dipping underneath - Got recovered home
Under tray covered in oil but the area it started from is where the O/S shaft goes into the gearbox
(Speedo drive? - 3x 13mm bolts) and the open portion where you can see the starter ring.
So i was 50/50 but hoping it was the shaft seal
Pulled the shafts and blocked / sealed the shaft holes at the box , Refilled the oil
On startup oil splattered out the open portion where the starter ring is ,
*Drilled a 6mm hole into the bottom of the bell housing and oil came out. .
Anyone had this before? I`ve made a start on removing the gearbox tonight
Has to be the input shaft seal? Weird. Can't imagine how it could pop like that unless something was generating heat and expanded the oil somehow.
Was it recently serviced or filled up? (Gbox)
My Van: 2012 B9 1.6 HDi Enterprise
[-] The following 1 user says Thank You to Zion for this post:
  • MB15
Check that the gearbox breather isn't blocked as this will cause pressure within the box.
  • MB15
Cheers guys ,
The only work that`s been done to that one was a CV boot & tyres back in January
Removed the gearbox today to find an inch hole on the inside
Find another box time  Rolleyes
 [Image: 040820.jpg]
What on earth has punched a hole there, I would be looking to find the bits and the cause. But as you say looks like another box is required.
2017 Enterprise - Possible to upgrade head unit ...
Last Post: lazy_pete
Today 10:09 PM
Introduction
Last Post: Mike
Today 10:04 PM
Washer pump dead
Last Post: Surfchickkelly
Today 09:21 PM
K9 van insurance
Last Post: Zion
Today 08:37 PM
Boot lock issue
Last Post: Mike
Today 07:49 PM
Central locking problems
Last Post: jonnyj6013
Today 07:32 PM
Thermostat hose clamp
Last Post: Glennyboy
Today 06:05 PM
DAB radio problems
Last Post: Pedronicus
Today 05:11 PM
Fan in front of radiator stopped working
Last Post: Berlingboy
Today 04:43 PM
Checking Maxi Fuses
Last Post: Zion
Today 01:41 PM
