Rubber pedal covers
Hi,
I can't seem to find anywhere that does the slip on rubber pedal covers for a B9 van. Anyone know where I can get a set please?
The part numbers are:
Brake pedal = 4504.31
Clutch Pedal = 2130.38
Try http://www.peugeotcitroendsparts.com - I use them and they are genuine parts. Or, search eBay with those numbers and take your chance. Parts on eBay may be pattern parts, but if they know enough to use the OEM part number then you have some hope the parts will fit ok.
(08-08-2020, 07:30 AM)Zion Wrote:  The part numbers are:
Cheers mate, however I'm having no luck finding them.
Here they are for £21 a pair. Several Citroen cars use the same parts, the part numbers match - some people just don't quote the dot in the number..
https://www.ebay.co.uk/itm/331614575575
(10-08-2020, 04:53 AM)Zion Wrote:  Here they are for £21 a pair. Several Citroen cars use the same parts, the part numbers match - some people just don't quote the dot in the number..
Thank you.
Today 02:32 PM
Berlingo 2026
Last Post: xtimex
Today 05:06 AM
Yesterday 12:15 AM
Yesterday 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
Weird Air in Fuel Problem
Last Post: tomhick024
27-06-2026 03:25 PM
