09-08-2020, 06:35 AM
Hi,
I'm hoping I could get a little help from the knowledgeable folks on this forum. I have a Berlingo 1.6 Multispace HDi manufactured in 2011 that unfortunately has a broken steering rack after only ~85000 KM. Not too uncommon as far as I understand, but still a PITA.
In order to change the steering rack, I understand I will need to drop the subframe a bit. However, some of the 4 bolts holding the front subframe to the chassis are now spinning. Citroen seems to have made an odd design choice where the bolts going through the subframe to the chassis are attached to a small square metal plate (this metal plate/sheet is acting as captive nut). However, there's no way to hold this metal plate as the access room is tiny and it's also hard to get anything to grip on a tiny metal sheet/plate. Cutting in the subframe and the chassis isn't legal under my countries laws.
A few questions:
1. Does anyone have experience with this problem? Preferably a solution that includes pictures![[Image: smile.png]](https://berlingoforum.b-cdn.net/images/smilies/smile.png)
2. Is there a way to access the metal sheet holding the spinning bolt from the floor of the passenger compartment or some other way?
3. Is it really necessary to drop the subframe to change the steering rack?
Thank you.
Accidentally posted this also in the wrong forum: https://www.berlingoforum.com/thread-197...#pid124678. If any admin is around, feel free to delete this post and move the other one here.
A few questions:
Thank you.
