11-08-2020, 02:34 PM
Hello all.
I went out to start the Berlingo the other day and had the dreaded 'click'.
Everything works on the electric front but after preheat when i turned the key just a click. Bugger. Out came a broom handle and a solid tap on the starter motor and we were off to get some bits, when out of the shop and back at the car....click. Needless to say i took the broom with me!
So i ordered a starter and have just fitted it.
For those worrying about doing this....stunningly easy.
Unclamp the battery positive terminal ......unless you like to see sparks and shock up your heart!
I removed the plastic cover on top of the engine. Friction clip on the right and a 13 mm bolt on the left.
I then removed the air filter pipe the runs from the front of the engine to the airbox. This has two jubilee clips holding it, one at each end. Prior to pulling it off though i saw a strange attached box attached to the pipe hanging under it also attached to the front of the engine with a 13mm bolt..had to lie under the car to reach this one. ( i presume this box is some type of moisture trap).
Next...three 8mm allen key bolts holding on the starter. Undo the electrical connectors on the starter solenoid first, 13mm bolt on the positive cable and an 8mm bolt on the earth, or it will be hanging on these when you take the three bolts out.
Lift out the starter carefully avoiding the radiator fins, there is plenty of space.
Refit in reverse.
All in all less than an hour including a nice cup of tea.
Refit in reverse.
It's a 2001 1.9d with 322,500 k on the clock.
