Knocking through steering wheel
Hi I just bought a berlingo van 66 plate after a couple of days it developed a knocking feeling through the steering wheel took it to citreon garage as has warranty on it they couldn't find anything wrong with it ☹️also when you turn steering wheel left and right there is a knock you can also feel the knock on the front wheels has any 1 else had the same problem??
If it's a constant clonk clonk clonk as you hold it in the left or right position, it could be the fluid level, or a bad electro hydraulic pump. If it's a single clonk when you first turn left, or right, it's probably a worn CV / knuckle joint on the steering column before it goes into the rack. The steering column makes a few twists and turns on its way to the rack. The knuckle joints are always at an angle.
(13-08-2020, 09:39 PM)bobsyg Wrote:  Hi I just bought a berlingo van 66 plate after a couple of days it developed a knocking feeling through the steering wheel took it to citreon garage as has warranty on it they couldn't find anything wrong with it ☹️also when you turn steering wheel left and right there is a knock you can also feel the knock on the front wheels has any 1 else had the same problem??
Yes then I tightened the wheel bolts and cured it Confused
Yesterday 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
