15-08-2020, 05:24 PM (This post was last modified: 18-08-2020, 11:38 AM by bk.bas99.)
2007 Berlingo 1.6hdi Coolant leaking under pressure when hot from under what looks like the vacuum pump. Maybe from under or around the black plastic thing with the coolant/heating bleed nipple and water pipes. I think it's the thermostat?
Its my friends. I don't know much about Citreon. I have VW that I maintain myself. Any ideas what it might be?
Hi Welcome , Is it a berlingo your talking about ? .
There are a lot of different models with a lot of different engines and its hard to guess what one you mean.
the year, model, petrol or diesel will help and if poss a photo of your problem area can bring results
2020 Rifter 1.5 allure
2010 B9 red XTR w a v. 2001 1.9d DW8B white Berlingo 2005 2.l green Berlingo 2001 1.9d DW8B white Berlingo berlingo 1.4 red multispace 1993 xud 1.9 red partner
(15-08-2020, 08:05 PM)brodfather11 Wrote: Hi Welcome , Is it a berlingo your talking about ? .
Sorry, thought I'd included that. Must have posted in too much haste.have amended OP
Coolant squirts backward toward bulkhead along shelf of engine block/cylinder head underneath thermostat....is it likely to just be the thermostat to head seal or something more sinister?
(15-08-2020, 10:44 PM)bk.bas99 Wrote: Coolant squirts backward toward bulkhead along shelf of engine block/cylinder head underneath thermostat....is it likely to just be the thermostat to head seal or something more sinister?
If you are sure it is not dripping from the bleed nipple, then most likely it is the thermostat gasket. These are known to become brittle with age. Not too difficult to replace.
16-08-2020, 09:21 AM (This post was last modified: 18-08-2020, 11:39 AM by bk.bas99.)
Cheers
No not dripping, it's a high pressure sqirt. Quite a lot. Gets worse as engine heats up. I'm thinking thermo gasket too. The bottom hose had come off the rad and dumped all the fluid. I think when it was put back on and the system refilled to get her home by a friendly forecourt guy it over pressured. When they released the bleed nipple a huge amount of air came out at quite high pressure.
Cheers
No not dripping, it's a high pressure sqirt. Quite a lot. Gets worse as engine heats up. I'm thinking thermo gasket too. The bottom hose had come off the rad and dumped all the fluid. I think when it was put back on and the system refilled to get her home by a friendly forecourt guy it over pressured. I released the bleed nipple and a huge amount of air came out at quite high pressure.
Check this video of repair to a leaking bleed valve/plug, could be an easy/cheap place to start. - https://youtu.be/Qa-92Xlon5g
The following 1 user says Thank You to ajb2494 for this post:1 user says Thank You to ajb2494 for this post • bk.bas99
Cheers
Does it come out under pressure from cold, or as soon as it starts to get warm? The head gasket may have gone and it's pressuring the water jacket.
(18-08-2020, 05:16 PM)Zion Wrote: Does it come out under pressure from cold, or as soon as it starts to get warm? The head gasket may have gone and it's pressuring the water jacket.
From cold. It starts and drives fine but leaves a trail of collant. She sent a pic. It's squirting towards the rear bulkhead along the edge of the block under the thermostat
