Front suspension drop link
Hello,
My Berlingo is suffering some age relate wear and the bushes on my drop links are all split and dry of grease.
Easy fix as it is just wheel off, undo the two bolts and either replace the rods complete or fit new rubber boots. With the price of these you may as well replace the links. I however had a couple of spare rubber boots that fit so i regreased and replaced them.
One thing that took me a short while to work out was how to remove the bolt as it just spun in place withouth loosening....on a closer look i saw you had to hold it in place with a 5mm allen key as you undid it!
It's a 2001 1.9d with 322,500 k on the clock.
[-] The following 1 user says Thank You to Carl.1 for this post:
  • Slimslim
Another picture
Good work! Most of the time there is also play on the bushes. I buy always new rod's and add some additional grease on the bearing. From factory, it's a very minimum of grease.
Berlingo M49 multispace 2001 1.6 16v TU5JP4
[-] The following 1 user says Thank You to Henk50 for this post:
  • Carl.1
I've always found them a pig to remove, often resorting to locking a narrow pair of long nose mole grips onto the threaded part behind the nut on the grease cap side to get them undone - the small allen is usually rusted out or rounds off immediately. Well worth replacing the drop links with new though.
  • Carl.1
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
20-04-2026 02:30 PM
Last Post: jw4821
20-04-2026 12:53 PM
Coolant
Last Post: tomhick024
19-04-2026 06:18 PM
