Threads: 2
28-12-2011, 09:58 AM
(This post was last modified: 10-08-2012, 03:26 PM by neil665.)
Can any members advise how to go about removing the battery for recharging and are there any special precautions I need to be aware of?
The car is a 55reg 2.0 HDI Berlingo.
Neil
Threads: 52
Thanks Given: 87
5
I remember a post
here from pk7478 giving advice about disconnecting the battery when jump starting another car to avoid burning out a diode bridge in the alternator. Don't know if that might be applicable here. FWIW
Threads: 20
Thanks Given: 2,126
18
I have never disconnected my battery for charging.It may be necessary to boost charge.My charger is a bog standard 6amp jobby,& is used once a month in winter due to less usage(I hibernate).
Mine is a 1.6 HDi '07,had it from new & guess it has been charged about 30 times.
Strawberry flavoured windows
Thanks Received: 19 in 14 posts
Thanks Given: 10
jumped mine a few times after leaving things on overnight.never disconnected it and no probs !
Threads: 17
Thanks Received: 14 in 10 posts
Thanks Given: 6
When I changed batteries recently I made sure I had the radio code.
Then I took the old battery out and fitted the new one.
OK so far.
But on opening the car door the alarm went off. It took me a minute the find the keys, blip the button twice to lock & unlock the car and then all was well.
'98 D 800 van
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Ok.
A diode bridge or bridge rectifier is protection against reverse polarity on a battery charger, for example. (A diode only lets current flow in one direction.)
This, like most sensitive electronics fitted to modern vehicles, could possibly be damaged by a high current surge, but not by voltage as you are never supplying more than 12v (or 13-14v from a charger) in to the battery.
In years gone by cars used a DC generator to charge the battery, but their output was dependant on rpm. At tickover less output current was produced.
(Remember dynamo lights on bicycles; the faster you pedalled, the brighter the lights.)
Modern alternators use voltage regulators to supply a constant voltage and more recent vehicles now use the ECU instead.
A diode bridge on an alternator converts the AC current to DC and they are about 70amps on a modern car.
As most battery chargers provide a quarter of that current, I cannot see how charging a battery when connected should cause a problem.
If you want to be on the safe side, disconnect one lead when charging. Doesn't matter which one, as you are 'breaking' the circuit.
