[Brakes] LUCAS front CALIPER
Threads: 5
Thanks Given: 4
21
Hi all, my 2002 Berlingo Multispace 1.4 has front Lucas calipers, solid discs. One caliper is getting sticky - have cleaned it all, pads out & pushed piston back, but still rubbing after a few miles. Can anyone point me at a new replacement - I can find plenty of Bosch, but not Lucas!
Cheers.
Threads: 67
Thanks Given: 238
50
Can you not get an exchange unit from a local Motor Factors ?
Possibly not a stock item but they should be able to supply the same day if you ask early enough or the next morning if not, mine operates this way - local Factors will supply the garage trade on a daily basis so it isn't an uncommon thing.
Years ago I'd buy new seals and refit but these days I'm more lazy.
Serieal Berlingo owner
• oilyrag
Threads: 75
Thanks Received: 1,306 in 1,140 posts
Thanks Given: 223
164
Maybe try your vin number in http://www.catcar.info - change the language to English and drill down to your brakes, the part number of the calipers and the details of what make etc should be there. Once you have the correct part number, you should find them.
If eBay have nothing, try http://www.peugeotcitroendsparts.com and use the "contact us" link, to send your vin number / enquiry, and Mike will reply with the correct part and a price. All genuine PSA parts.
The following 2 users say Thank You to Sol for this post:2 users say Thank You to Sol for this post
• ian432, oilyrag
Threads: 5
Thanks Given: 4
21
(24-08-2020, 09:29 PM)Zion Wrote: Maybe try your vin number in http://www.catcar.info - change the language to English and drill down to your brakes, the part number of the calipers and the details of what make etc should be there. Once you have the correct part number, you should find them.
Thanks lads,
I live in a very rural part of Ireland so the chance of finding someone capable of a quick turnaround on a refurb won't be a possibility, but I'll follow up all ideas!
Threads: 5
Thanks Given: 4
21
(24-08-2020, 09:24 PM)geoff Wrote: Can you not get an exchange unit from a local Motor Factors ?
I've now found a seal kit, so may go down the home rebuild route - as you say, I was looking at the lazy option!
Threads: 75
Thanks Given: 223
164
If the piston is rusty (usually are outside the seal area) then you would always be better with a new caliper, and I would always do both sides to make sure braking is even - don't want pulled into a ditch in winter on a country road!
Go to that site I said ( http://www.peugeotcitroendsparts.com ) and send them your VIN number, tell them what you need, they will email straight back with the right parts & a price, I've bought loads of hard to get stuff from them, they are diamond mate.
Threads: 5
Thanks Given: 4
21
(25-08-2020, 04:21 PM)Zion Wrote: If the piston is rusty (usually are outside the seal area) then you would always be better with a new caliper, and I would always do both sides to make sure braking is even - don't want pulled into a ditch in winter on a country road!
Well lads,
I managed to get hold of 2 seal sets from a seller on Ebay called frentech-uk, suitable for Lucas front calipers - good quality, with all necessary greases and seals. Pushed pistons out with compressed air, and they cleaned up very well, then heated the castings to ease out the bleed screws, which had corroded 'nut' faces. Filed the nut 'points' a little and then ran an 8mm die up the bleed screw, cutting a thread onto where the nut used to be. Turned an 8mm nut down to half thickness, ran this up to the 'new' thread and then welded the nut just below the nipple end, making sure that there was still a gap between the lower face of the nut and the caliper casting. This was to be certain that the cone face of the bleed screw would be fully set against the casting when done up. I can now use a 13mm spanner to bleed the brakes!
Cost was £18.00 to do both.
Much as it would have been far easier to buy replacement calipers and even just new bleed screws, it turned out to be an enjoyable bit of mending that has all gone back together well. (I hope!)
The following 1 user says Thank You to oilyrag for this post:1 user says Thank You to oilyrag for this post
• geoff
Threads: 75
Thanks Given: 223
164
Nice one, now that's a proper fix. God I wish I had a lathe again.
Side Light Bulb Holder
Yesterday 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
