LCD panel that controlled by the R/H stalk
I have a 2013 Berlingo, It has a mono chrome panel that you can scroll through using the button on the end of the R/H stalk. I have worked out some of them like the date, time, MPG, and the vacuum MPG.The one i can work out is the last one in the sequence it show MPH 23 what is this????
One last thing is the wiring loom the same in all berlingo's, i am just thinking of installing say a later radio than what i have.
(25-08-2020, 12:01 PM)hawkeyefxr Wrote:  I have a 2013 Berlingo, It has a mono chrome panel that you can scroll through using the button on the end of the R/H stalk. I have worked out some of them like the date, time, MPG, and the vacuum MPG.The one i can work out is the last one in the sequence it show MPH 23 what is this????
MPH 23 is Probably your average speed. Sounds like the most basic display, a bit different to the next one up.
If you add a non standard stereo, you need a kit to convert the canbus system to keep using that display from the stalk button, or you lose all ability to use it at all, and can't even set the time & date. The control functions for the trip computer and hands free (if you have it) are all built into the oem stereo and without it, they no longer work.
If you use a later standard Berlingo stereo like the CD45 with hands free bluetooth etc, it will work fine, but you need to know the last 8 digits of the VIN of the vehicle it came from, as they are all coded to the cluster via the VIN number and it won't work unless re-coded or you know the donor vehicle VIN number. It would have to virginised and then coded to your car with Citroen DiagBox to stop it asking for the code every time you turn it on.
Last Post: mikeh79
Yesterday 07:00 PM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
03-11-2025 08:08 PM
02-11-2025 07:53 PM
Boot liner with 7 seats
31-10-2025 07:57 PM
Last Post: Buki
31-10-2025 07:26 PM
