An indicator you can add to know when a DPF regen is happening...
I found a guide on C4 owners.org, regarding an indication LED to show when a regen is taking place. Now since the B9 is really a C4GP under the skin, then this may also work and is totally testable, or removable if it doesn't work.
You need a 12v led with wires already on it preferably, from eBay or similar.
When the car does a regen, apparently it switches on the heated mirrors, but does not light the indicator inside, on the heated screen / mirror button. So, you can add an LED to the heating connector behind the mirror glass and if it comes on when you don't have the mirror heating on, the ECU is doing a regen.
Details attached in a pdf. Well worth a try.
Obviously you need the heated mirrors option already enabled I guess but it may work as long as the brown wires are there, inside the mirror housing. You can test the LED polarity by switching the mirror heating on and making sure the LED comes on manually.
No idea why the car does this, but very handy.
.pdf   C4 Installing Re-gen LED.pdf (Size: 771.72 KB / Downloads: 66)
______________________
Not a Citroen!
2017 B9 1.6 BlueHDi Van
2012 B9 1.6 HDi Van
2008 M59 1.6 HDi Van
2003 M59 1.9D Van
[-] The following 2 users say Thank You to Sol for this post:
  • ron, spurs
When doing a regen the ecu puts on several high amp consumers to load the alternator, especially needed if you are driving slow in town. Regen will fail if engine is not doing enough and have to start again later. If regen fails several times that is when you get real problems and end up having to get a forced regen at a dealers or an off the car cleanout.
[-] The following 1 user says Thank You to RobS for this post:
  • Gryffindor
But how will you know the regen is happening.....hence my previous post.
If you drop below 60 mph, the regen will stop. It doesn't do a regen at town speeds.
Not a Citroen!
2012 B9 1.6 HDi Van
2003 M59 1.9D Van
I have a Vauxhall with a DPF and they will try to regen at town speed if it gets really badly full and you are not doing any high speed driving. There is no indicator for a normal high speed regen apart from smelling hot. When doing one of the low speed job there is a dash indicator and the heated rear window is on as well. The owners manual tells you to drive in a low gear keeping the revs over 2000 and keep driving until the regen light goes out.
(02-05-2021, 05:07 PM)RobS Wrote:  When doing a regen the ecu puts on several high amp consumers to load the alternator, especially needed if you are driving slow in town. Regen will fail if engine is not doing enough and have to start again later. If regen fails several times that is when you get real problems and end up having to get a forced regen at a dealers or an off the car cleanout.
What a great bit of knowhow - thanks. Explains why my Volvo truck has to go through several cycles even though each one ends with a 'regen completed' message. It always seems to want to regen in town when at low or zero road speeds as well.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
(31-08-2020, 08:57 AM)Zion Wrote:  the B9 is really a C4GP under the skin...
Really?
Sorry for veering OT but I have to ask - I know you're speaking of the mechs and elecs, but would the front seats be cross-compatible in terms of rails/fixing?
53 1.4i MS MPV RIP
08 C4GP 1.9 VTR+
Could be mate, I know the two vehicles are identical under the skin, brakes, shocks, suspension, all parts are interchangeable. The body shell is different looking and the interior may be too. But the mounts should be the same as the floorpan should be exactly the same.
Not a Citroen!
2012 B9 1.6 HDi Van
2003 M59 1.9D Van
Floorpan - of course. Much thanks!
Reminds me of when some bod at Vauxhall had a brainwave when tasked with solving a massive overstock of Astra floorpans - he invented the Zafira.
53 1.4i MS MPV RIP
08 C4GP 1.9 VTR+
Brake problems again!
Last Post: Robho
Today 11:55 AM
CITROEN VIRTUAL SERVICE MANUAL ALL MODELS
Yesterday 05:34 PM
» Replies: 33
P0691 P0693 cooling fan circuit problem
Yesterday 07:32 AM
Does My Van Have A Tracker ?
Last Post: Mark604
17-06-2025 03:01 PM
Seatbelt pretensioner or airbag fault
15-06-2025 09:02 PM
'Airflow higher than recommended'
14-06-2025 10:57 AM
» Replies: 36
M59's must be getting old I guess ... Lol !!
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
