Satellites are back in view
Hi, I’ve recently bought a 2015 enterprise van
One of the problems it has is that it constantly says “satellites are back in view”
I guesss this is from the old sat nav but I don’t have this anymore.
I’ve checked all the menus but cant find a way to disable it.
Or remove a fuse to disconnect it.
Does anyone know how to stop it? It says it even when the van is locked through the night. So is draining the battery too.
Did you have the separate teletrac sat nav on the driver's side dash mount? If so, there should be a box behind the glovebox for the teletrac unit, it has a fuse in it you can pull to disable it completely. (two fuses actually) and the box should be fairly small, marked with the SIM number and Teletrac or Navmaster
Yes there was a separate unit, I will go have a look.
Thanks a lot for your help
(01-09-2020, 03:36 PM)Berlingovan Wrote:  Yes there was a separate unit, I will go have a look.
Hi just wondering if you managed to sort this problem
And if so how
Because I am having the same problem with my citroen relay
I unplugged the satnav as it didn't work but I still get sound from the speaker saying satellites back in view
I I don't know where to start
I'd throw the teletrac in the bin mate, that's what everyone else does. Use Google maps on the phone or buy a TomTom.
And if so how
Yes I sorted the problem, there was a speaker wired in that I removed, I think I just disconnected the wires. I can’t remember as it was a couple of years ago but I’m sure I took the glovebox out and it was behind there. It’s not through the van speakers.
Today 12:29 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
