Horn Intermittent
I've found my first fault, on what has been an excellent car, and although it's super minor, I do have an mot coming up.
So here's my questions
1) where is the actual horn on the car?!
2) has anyone experienced an Intermittently working horn, if so how did you fix it?
Cheers
Sent from my SM-G950F using Tapatalk
Yes , I had a similar problem. I tired the actual steering wheel, but that didn't fix it. The horn is very difficult to get to low down behind a cross member, I fixed the fault as it turned out to be the horn relay fixed to the battery box. Now works fine.
I have had this problem and it was the earthing tag on the steering wheel. Disable airbag remove horn section and clean the brass earthing tag with sandpaper to ensure a good connection.Solved my problem.
Today 05:26 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
