Hi guys,
So I have a feeling I need a new clutch.
Got the van at 58K in June, now it’s at nearly 65K. Was a bit stiff then but definitely stiffer now.
It’s stiff in operation at all times and I can hear a slight rattle when in neutral that goes away when engaging the clutch. Fluid could do with changing by the looks of it but it’s midway between max and low currently.
I have also sprayed some silicone oil into the slave cylinder under the boot, as I saw this mentioned. I’ve not had a chance to really test it properly yet, might be a bit better but will know more tomorrow on an extended test.
Anything I should look for other than the above? I’m doubtful that the issue is with the hydraulic system as all seems smooth.
Also what kind of price should I be looking at for a fitted replacement?
