De badged rear
Hi has any one got pics of the rear of a multi space 2009 that’s been rebadged thanks
No, but I've done it before and am going to take my Berlingo badge off to swap it for the chevron badge from the facelift B9. Best thing to use is a piece of fishing line or dental floss, sawing through the foam backing on the badge as it doesn't affect the paint. Then use isopropyl alcohol to remove the rest and finally t-cut to remove the shadow.
White Spirit / WD40 also removes the sticky adhesive stuff.
(13-09-2020, 04:13 PM)Zion Wrote:  No, but I've done it before and am going to take my Berlingo badge off to swap it for the chevron badge from the facelift B9. Best thing to use is a piece of fishing line or dental floss, sawing through the foam backing on the badge as it doesn't affect the paint. Then use isopropyl alcohol to remove the rest and finally t-cut to remove the shadow.
Thanks for that bud,I normally do it on every car I’ve had,always used dental floss and Wd40,just wanted to see what it would look like ?
(13-09-2020, 07:09 PM)jj9 Wrote:  White Spirit / WD40 also removes the sticky adhesive stuff.
cutout from a video on my FB... hope it shows enough
Last Post: Matt Haigh
Today 11:45 AM
One thing after another
Yesterday 10:56 AM
Yesterday 08:44 AM
12-11-2026 10:15 AM
