How to get behind the blank buttons on the dashboard
Hi
08 Berlingo Multispace Forte. We want to use the space that is currently covered by a round blank on the dashboard but we can't work out  how to get behind it to fasten a switch in place.  Does anyone know how to do this?
The rectangular plastic panel surrounding those switches just clips into place, and in theory can be removed by prising it off with a flat blade (screwdriver, paint scraper).
To get full access to the switch wiring etc. you may need to remove more than this, i.e. first the top tray/MFD display shroud (also just prises off from its sides), then the panel surrounding the air vents & hazard switch (fixed by screws hidden under both those panels), and possibly also pull out the radio.
The complete process is described with photos in the Haynes manual, page 11.24.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
Thanks Rasputin
(17-09-2020, 10:00 AM)vampirequeen Wrote:  Hi
I had to remove the heater bulbs once and made a video. Maybe this will help: https://www.youtube.com/watch?v=iJKvvFs37OE
Wow Saskak.  That's brilliant.  Just what we needed.  Thank you.
A good vid, Saskak, well done. I thought the heater control panel was sealed and non-serviceable! You learn something new all the time.
53 1.4i MS MPV RIP
08 C4GP 1.9 VTR+
(18-09-2020, 03:51 PM)Rasputin Wrote:  A good vid, Saskak, well done. I thought the heater control panel was sealed and non-serviceable! You learn something new all the time.
Necessity teaches, I could not stand the one broken bulb, although should have replaced all 3.
Lets just hope they all stay working :Smile  I so hate finishing a job, only to have to do it again a few days later
2007 Peugeot Partner Zenith RIP Sad
2010 Seat Ibiza ST
I just found this - very similar advice, but (from about 2:30) comes up with an easier way to change the bulbs.
https://www.youtube.com/watch?v=RZjhbtcQeaQ
Boy does the bloke blether though!
53 1.4i MS MPV RIP
08 C4GP 1.9 VTR+
[-] The following 1 user says Thank You to Gryffindor for this post:
  • saskak
(19-09-2020, 07:23 PM)Rasputin Wrote:  I just found this - very similar advice, but (from about 2:30) comes up with an easier way to change the bulbs.
Yep, that is a better way, my search did not find it when I wanted to do it, stupid youtube algorithm.
Last Post: Beaumotor
Yesterday 04:38 PM
engine light
Yesterday 09:25 AM
M59 1.4 Petrol question
19-03-2025 06:12 PM
Cold Starting
Last Post: jboy012000
18-03-2025 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
