Threads: 2
21-09-2020, 11:02 AM
(This post was last modified: 22-09-2020, 05:45 PM by Mike.)
He tenido esta furgoneta desde hace mucho tiempo y nunca me dio problemas. Pero desde hace poco la noto como un sonido un poco raro al arrancar. Alguien sabe algo?
***Please post in English***
I have had this van for a long time and it never gave me problems. But recently I notice it as a little strange sound when starting. Does anyone know something?
Threads: 75
Thanks Given: 223
164
21-09-2020, 02:07 PM
(This post was last modified: 22-09-2020, 05:46 PM by Mike.)
Hola, si es un sonido como RRRRRRR después de arrancar el motor, es posible que el motor de arranque no se desacople correctamente. Esto podría deberse a que el solenoide no se retrae rápidamente en el motor de arranque. Si está rechinando, el motor de arranque o los dientes del volante pueden estar desgastados.
Hi, if it's a sound like RRRRRRR after starting the engine, the starter motor may not disengage properly. This could be because the solenoid is not retracting quickly in the starter motor. If it's grinding, the starter or flywheel teeth may be worn.
Threads: 0
Where does this strange noise come from?
Exactly which part is the problem?
Threads: 0
In your case, I would go to the official workshop to have the diagnostic machine connected. It's probably a minor problem
