Cigar light
Anyone know how it's held in.
I have been using it as a socket that i plug an extension lead into giving me three sockets and four USB sockets, problem is it's very intermittent the plug that goes into it had to be at a just so angle.
.tb_button {padding:1px;cursor:pointer;border-right: 1px solid #8b8b8b;border-left: 1px solid #FFF;border-bottom: 1px solid #fff;}.tb_button.hover {borer:2px outset #def; background-color: #f8f8f8 !important;}.ws_toolbar {z-index:100000} .ws_toolbar .ws_tb_btn {cursor:pointer;border:1px solid #555;padding:3px} .tb_highlight{background-color:yellow} .tb_hide {visibility:hidden} .ws_toolbar img {padding:2px;margin:0px}
I had a similar problem on my (previous) 2010 B9 Multispace, the dealer replaced it for me as an addition to a routine service and it didn't cost much.
The explanation that the dealer gave me (not sure I'm 100% convinced?) was that there is a dimensional difference between the socket that is described as a "power outlet" compared to the one I had which they called a "cigarette lighter socket"
My socket worked perfectly as a power outlet from then on
Found this with a quick Google search ....
......... "Accordingly, the specifications for these power sockets that are contained in ANSI/SAE J563 include two variants: one that works with cigarette lighters and one that doesn’t. If you've ever tried putting a cigarette lighter into a cigarette lighter socket only for it to fall right back out, that's why."
Matt
   previous
   2016 1.6 HDi 100 XTR Grey Met
   2010 1.6 HDi 105 XTR Gold Met
I think it's the fact that cigar sockets have 2 bi-mettallic springs to lock the lighter in place till it gets hot enough to pop up. They get in the way of power plugs and if they have been used to light cigarettes, the main positive pin at the bottom is usually skanky with carbon anyway.
Power sockets have neither the bi-metallic latching springs on the sides of the positive pin, nor the carbonised deposits.
(29-09-2020, 10:42 PM)Zion Wrote:  I think it's the fact that cigar sockets have 2 bi-mettallic springs to lock the lighter in place till it gets hot enough to pop up. They get in the way of power plugs and if they have been used to light cigarettes, the main positive pin at the bottom is usually skanky with carbon anyway.
I always thought they were the same but it makes sense about the different types. The bottom contact on mine is clean so never been use to light ciggies (orriblle things).
I should have looked when i changed the gear lever boot, may gird myself and and take the cover off again.
I will try it in the rear one and see what happens there.
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
Gen 1 cream interior cleaning
07-05-2025 06:28 AM
