  • 8 Vote(s) - 2 Average
Anybody solve the automatic left indicator issue?
Hi All
When I indicate to turn right, the self cancelling indicator goes straight to a left turn and not the cancel position.
I have read the thread about making a left turn to compensate Smile
Any other solutions?
Happy New Year
CraigE
Have a look at the last post here:-
http://www.berlingoforum.co.uk/showthrea...9#pid14309
The solutions could vary, depending on your mechanical ability.
The problem is not uncommon on MkI and earlier MkII Berlingos and the other Citroen models which share the same COM2000 unit.
If you take it along to a Dealer or approved repairer a new COM2000 will be fitted.
It is possible to strip out the existing unit and modify the switch return mechanism by removing the auto-return latch then
you have a switch which will require manually cancelling the indicators (like older cars used to have).
I think that the COM2000 has to be completely removed to carry out this work and in order to remove it the steering wheel air-bag
assembly also has to come off.
There are existing posts here which describe the removal of the COM2000. In fact Andre has recently posted a tutorial with pictures.
OMG, that sounds expensive or very complicated.
May put up with it for now.
Thanks for the constructive replies
M59 1.4 Petrol question
Last Post: Gadgetman
Today 01:30 PM
Cold Starting
Last Post: jboy012000
Today 10:46 AM
Yesterday 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
