Power steering fluid
Hi I’m looking for some advice, I have a 2013 berlingo enterprise 1.6, I am told that it has an electric steering pump. I need to top up the power steering fluid but can’t seem to find a spec for the fluid/oil. Is it only a main dealer that can supply or is there a fluid type?
Hi there, welcome to the forum.
The fluid is "Fluide LDS". To get the exact details for all Citroen or Berlingo variants, go to
https://www.total.co.uk/lub-advisor
and enter your Reg number, then press "Enter" - the first fluid that will be recommended is the correct engine oil - but click on the blue "other components" tab at the right hand side of the red bar, then select "Power Steering" - so for your own confirmation, use the tool on the Total site.
They (Total) are the French OEM oil supplier to Citroen. There is a live chat too, where you can ask questions on fluids directly.
I've attached the data sheet from Total on my van, which is a B9 2012 1.6 HDi 75 (9HN engine)
.pdf   B9 (9HN).pdf (Size: 147 KB / Downloads: 33)
[-] The following 4 users say Thank You to Sol for this post:
  • Aigburth Lad, Pedronicus, rnamman, Teep
Thanks!
Mileage
Yesterday 04:33 PM
eolys
Last Post: magoo1
19-05-2026 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
