Front hub nut torque?
I wish I had found this forum a few days ago! Can anyone confirm the torque for the front hub nut, I have changed out the outer CV joint and track rod ends and Wishbone, it’s all back together but I am unsure how tight to do the hub nut. Any help would be much appreciated.
Assuming it's a B9 2008-2016 then Haynes gives the torque of the drive shaft retaining nut as 312Nm (232 lbf ft).  They also suggest the nuts are tightened up once the vehicle is resting on it's wheels again.
[-] The following 1 user says Thank You to Pedronicus for this post:
  • 3dwilliams
Unless you're particularly fat or have a very long bar, then doing it up as tight as you can is the simple option - not many torque wrenches even measure that far. As long as the retaining clip is in place it shouldn't then fall off! You'll have trouble achieving that figure unless the wheel is on the ground, so tighten up the hub nut as far as possible with the wheel off first, then fully when on the ground.
The only nuts that should be slackened/retightened will be those that grip rubber bushes, so only the inner wishbone bolts need to be done with wheels on the ground/ramp. This allows the bush to be in the best operating position rather than being in a twisted state.
(15-10-2020, 03:48 PM)oilyrag Wrote:  Unless you're particularly fat or have a very long bar, then doing it up as tight as you can is the simple option - not many torque wrenches even measure that far. As long as the retaining clip is in place it shouldn't then fall off! You'll have trouble achieving that figure unless the wheel is on the ground, so tighten up the hub nut as far as possible with the wheel off first, then fully when on the ground.
Thank you - I had not come across that before I'll do that tomorrow before it goes back for its MOT, so on the wishbone now its back on the ground I just slacken off the nuts and then retighten them - that's all and just see that the rubber bushings slide a bit flatter?
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
20-04-2026 02:30 PM
Last Post: jw4821
20-04-2026 12:53 PM
Coolant
Last Post: tomhick024
19-04-2026 06:18 PM
