What are these bits called and where to find them?
My van is missing some bits, and I like to replace them. But I cannot find them, nor do I know what the partsnumbers are Sad
The right side is missing this black trim piece. I tried fitting a 2003/2004 ish trim piece, but aparently the 2007 model is a lot bigger.
So far no luck on scrapheaps and allready a little passenger got her fingers caught between the door and handle so I really want this trim back.
The doorhandle trimpieces are very worn down. Me trying to paint them only made things worse and id like some new ones.
Dont care about the color, if its the standard black/greyish thats fine. I allready swapped the once silver gearknob for a standard black one and it doesnt bother me.
And last but not least; The sparewheel cage, what a sh*t design, I spend two hours today getting the wheel out. The bolt and hook are sooo rusted and are never ever comming apart again. Only option I see is to cut it out. Can this bolt and hook be bought new? All the junkers I looked at where in no better shape then mine.
2007 Peugeot Partner Zenith RIP Sad
2010 Seat Ibiza ST
Catcar will give you the part numbers, where you get them from is a different matter!
http://www.catcar.info/citroen/?lang=en
Here you go its not genuine but it should be right, https://www.ebay.co.uk/itm/Spare-Wheel-C...%3A2334524
If the bolt isnt greased they seize up as you have found. You may be able to find one cheaper if you have a search.
Thanks guys Smile
2010 Seat Ibiza ST
So I got the partnumbers, and ofcourse nobody sells them Sad
2010 Seat Ibiza ST
Try https://peugeotcitroendsparts.com/produc...780p7.html
They will tell you by part number if they can supply the part, just search or contact them
(18-10-2020, 06:12 PM)Zion Wrote:  Try https://peugeotcitroendsparts.com/produc...780p7.html
I did look at that shop, but the website seems dodgy and the reviews arent that great either.
2010 Seat Ibiza ST
I've bought loads of parts from them, they are genuine. The company is Endon Services Ltd and they are a UK business. Totally legitimate buddy. A proper authorised distributor of PSA parts.
  • mission
Thanks, will have a better look at them
2010 Seat Ibiza ST
No problems buddy. The guy I deal with is Mike Aldridge, his email is mike@endonservices.co.uk and if you email him with your part number, he will tell you the price and availability. He's a great guy, really helpful. I've bought really hard to find parts from them and have never been let down or had any problems.
Let me know how you get on Smile
10-11-2026 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
