Will my mobility scooter fit
I cannot find a length of the boot space when the seats are folded forward.
I an considering an XTR newish model or dar I say a Caddy maxi life
If it helps the length of the boot space on my 2016 XTR (B9) with the second row of seats folded forward but not taken out is 1160mm. With the seats taken out all together the length increases to 1300mm to the front edge of the load space floor. From that point to the back of the front seats (over the rear seat footwell) is 380mm.
[-] The following 1 user says Thank You to Pedronicus for this post:
  • uchitermon
(17-10-2020, 05:11 PM)uchitermon Wrote:  I cannot find a length of the boot space when the seats are folded forward.
There are plenty of Berlingo & Caddy Wheelchair Access conversions, might be a good idea to call some of the resellers of used conversions if a mobility scooter will fit.
  • uchitermon
Yesterday 12:02 PM
Berlingo 2026
Yesterday 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
