18-10-2020, 11:10 AM
(This post was last modified: 18-10-2020, 11:14 AM by Thisisnotaspoon.)
Just a quick post as I did a quick search and couldn't find the info so it might be useful for someone.
12V from the battery, a couple of 6mm ring crimp's (toolstation 59929), some spade connectors (with added heat shrink insulation as I didn't have the insulated type to hand) and some 10A blade fuses. I'll change it to a proper fuse holder at some point.
The cable is speaker cable, it's not quite as robust as automotive cable, but from experience on my last car you lose a lot of volts if you use the recommended gauge, and speaker cable is a significantly cheaper way of getting a lot of copper!
One cable feeds the bypass relay, the other feeds the 12V socket and USB.
Both fused at 15A, the cable could comfortably take many times that but I was being cautious.
![[Image: 50500957026_0966d3c80b_o.jpg]](https://live.staticflickr.com/65535/50500957026_0966d3c80b_o.jpg)
Dropping down and out the back of the 'transmission tunnel' (I'm more used to working on RWD cars!) following what I presume is one of the brake lines (could be diesel). I had to drill an extra hole and file it out to a rectangle to get the cable through the boot floor. Many layers of gorilla tape were added to stop it chafing through.
![[Image: 50500245738_04fa0a9515_o.jpg]](https://live.staticflickr.com/65535/50500245738_04fa0a9515_o.jpg)
A bit of a rat's nest. Colour coding is:
Right hand side:
Indicator - cream
Reverse - White
Tail - Pink
Brake - Orange
Fog - Brown
Left hand side:
Indicator - yellow.
I ran the wire for the LH indicator out the light cluster foam seal, and pulled off the boot seal to tuck it behind, around the top and in the foam seal on the other side. I didn't bother splitting the two tail lights and just wired the brown and black relay wires (L and R tail) together. I figured if there ever was a scenario where I wanted just one tail light on having both on the trailer wasn't going to be an issue!
Weirdly, input and output wiring on the relay doesn't follow the same colour code.
Double earth wire for the 12V socket just because I could, single for the USB.
Power gets from the 12V to the USB via a piggyback spade connector.
Had to tape the sockets in as I long ago lost the nuts!
![[Image: 50501116532_91ec2f40e5_o.jpg]](https://live.staticflickr.com/65535/50501116532_91ec2f40e5_o.jpg)
Ta Daaaaaa!
![[Image: 50500957156_9eaecbdbf8_o.jpg]](https://live.staticflickr.com/65535/50500957156_9eaecbdbf8_o.jpg)
Still to do:
Add propper inline fuse holders.
Add a leisure battery to the boot and a split charge relay so that whatever is plugged in doesn't drain the chasis battery.
Right hand side:
Indicator - cream
Reverse - White
Tail - Pink
Brake - Orange
Fog - Brown
Left hand side:
Indicator - yellow.
Ta Daaaaaa!
Still to do:
