Setting clock to winter time
I have changed the Citroen radio for a Kenwood DMX7017DABS, radio works fine as does the steering column stalk.
But how to i change the clock time from summer to winter time !!!?
.tb_button {padding:1px;cursor:pointer;border-right: 1px solid #8b8b8b;border-left: 1px solid #FFF;border-bottom: 1px solid #fff;}.tb_button.hover {borer:2px outset #def; background-color: #f8f8f8 !important;}.ws_toolbar {z-index:100000} .ws_toolbar .ws_tb_btn {cursor:pointer;border:1px solid #555;padding:3px} .tb_highlight{background-color:yellow} .tb_hide {visibility:hidden} .ws_toolbar img {padding:2px;margin:0px}
I switched back to the original radio to change the clock... Would be great if I didn't have to do that though! Also, on the original head unit there is a "Dark" button that switches off the clock display. Can this be controlled if you have an after-market radio?
I think you can try this...
Press both top and bottom buttons on the audio stalk together for a second, (not the volume ones, but the outer ones) that should trigger the settings menu on the MFD, then use the wheel, outer or volume buttons to navigate and get through the menus. The end button may function as an OK button. You may have to play a bit with it to get it done.
[-] The following 2 users say Thank You to Sol for this post:
  • Matt Haigh, Tobbe
(31-10-2020, 11:42 AM)Zion Wrote:  I think you can try this...
Just tried this and it did not work  Huh, got all excited there  Big Grin
There is a connects2 adaptor that allows the use of the volume stalk, and it does work this way if you have the adaptor harness fitted, sorry for getting the hopes up, if you swapped the original stereo out and didn't fit the special harness for the audio stalk, then there's no way to change the clock.
I assumed since it's been mentioned so many times online, that everyone who swaps out the original stereo would fit the connects2 harness as well.
Sorry mate!
One thing after another
Yesterday 05:02 PM
Yesterday 10:41 AM
» Replies: 16
Yesterday 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
