Threads: 41
Thanks Received: 2 in 2 posts
Thanks Given: 28
Hi there,
I have a 2002 berlingo multispace 16v 1.6 and just wondering if anyone could tell me how I should put front fog lights on?
Also can anybody tell me which one to put on and where to buy them?
Thanks.
Thanks Received: 13 in 12 posts
Thanks Given: 4
On a M59 the foglights are operated by a ring on the left stalk
I wouldnt bother trying a retrofit and just install a led bar in the bumper.
As for the foglights you need a different bumper, lights, housing, wiring, new left stalk and probably some ecu programming.
2007 Peugeot Partner Zenith RIP
2010 Seat Ibiza ST
The following 1 user says Thank You to mission for this post:1 user says Thank You to mission for this post
• Squad
Threads: 48
Thanks Given: 4
20
2002?
Are you certain you have an M59, and not the M49?
(The headlights is the big clue. The M49 have the 'narrow slits' )
I think there's a button somewhere on the dash for fog lights. Can't remember where, right now.
Threads: 44
Thanks Given: 97
28
People carriers can be M49s as well as vans!
This ad is for an M49:
https://www.ebay.co.uk/itm/154167986291
This is for a (very expensive IMHO) M59:
https://www.ebay.co.uk/itm/264889442602
As Gadgetman says, compare the headlight shapes.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
Threads: 44
Thanks Given: 97
28
Just happened to notice these in passing - what would others think to cutting holes in the front bumper to slot these into?
https://www.ebay.co.uk/itm/133168935932
FOR CITROEN BERLINGO FRONT FOG LIGHT GRILL FRAME PAIR 7452.Y7 (1996-2011)
I'd still suggest adding your own switch and relay rather than using a cluster stalk because of the programming it would need, but if these things would work then at least the lights would look like part of the car from the outside.
53 1.4i MS MPV RIP
08 C4GP 1.9 VTR+
Threads: 44
Thanks Given: 97
28
That's an M59 then! Must be one of the very first - it's usually said that they came out in 2003, but I note here that it was actually Dec 2002!
https://en.wikipedia.org/wiki/Citro%C3%A...2003-2013)
53 1.4i MS MPV RIP
08 C4GP 1.9 VTR+
Threads: 75
Thanks Received: 1,299 in 1,139 posts
Thanks Given: 223
163
03-11-2020, 06:53 AM
(This post was last modified: 03-11-2020, 06:57 AM by Sol.)
52 reg spans up to March 2003 if I remember correctly.
Yours was built on 10 December 2002 so it must be one of the earliest M59 around.
