Leisure battery under bonnet ?
Has anyone managed to mount a leisure battery under the bonnet rather than in the car ?
Mine is a 2002 1.4
Cheers
(03-11-2020, 02:17 PM)composimmonite Wrote:  Has anyone managed to mount a leisure battery under the bonnet rather than in the car ?
Mine is a 2002 1.4
Cheers
I'm looking at installing under the bonnet, wondered if anybody has?
My standard 1.4 battery crapped out last Easter, so I thought I'd put an almost new leisure battery in its place and use that for a while, but the battery 'box' - rigid plastic - is too small and there's no scope to either remove or enlarge it as there's a lot else in the way. I don't see that there's enough space elsewhere in the engine compartment if you're planning adding the second battery. It's a mighty heavy item to secure safely.
(29-11-2021, 09:19 PM)oilyrag Wrote:  My standard 1.4 battery crapped out last Easter, so I thought I'd put an almost new leisure battery in its place and use that for a while, but the battery 'box' - rigid plastic - is too small and there's no scope to either remove or enlarge it as there's a lot else in the way. I don't see that there's enough space elsewhere in the engine compartment if you're planning adding the second battery. It's a mighty heavy item to secure safely.
There isn't a lot of space.  There is a void below the bottom of the battery and fusebox going into the nearside wing. half the battery would be behind the back of the radiator. Was thinking a making a shelf suspended from above fixed to the chassis where the fresh air intake duct is fixed. and or possible re route the fresh air intake
Yesterday 03:29 PM
Last Post: Triggermann
Yesterday 01:47 PM
15-07-2026 12:17 PM
Last Post: wbchevron
15-07-2026 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
