[Transmission] Mass Gearbox fluid leak
I have citroen berlingo 2013 automatic gearbox. suddenly had fluid discharged on the road as I reversed off of driveway, and now only stays in neutral. No problems previously. Has anyone had this happen?, Do you know if it is gearbox or ECU problem./ Clutch actuator pproblem.
Welcome to the forum.
I am not an expert on the Auto Box, but would think that your problem is due to a fault in the gearbox. Hopefully someone with more knowledge will be along soon, but in the meantime I suggest that you do not start the engine or tow the car.
  • MEPEDRO
I think the clutch actuator (slave cylinder) is a problem area, also the clutch must have a hydraulic pump which could have failed or burst a fluid line - what colour is the fluid? Clear / yellow? It is likely to be clutch fluid so check the clutch reservoir as it is probably empty or low. This would confirm it.
The B9 auto is actually a manual gearbox with an automated shift and clutch, not a conventional auto with a torque converter (slushbox)
Since it is a manual gearbox at heart, when the clutch fails you cannot move it out of Neutral.
  • MEPEDRO
Hello I had the same problem it’s usually a leak from the plastic black pipe which returns fluid from pump back to reservoir if you look down to the right of the black bulb you will see a tank and you will be able to see if it is empty here is a link from a c4 Picasso but same system https://www.bing.com/videos/search?view=...4L52VGzSDg
Back pain / ache
Last Post: jw4821
Today 06:23 PM
Indicator/lights Stalk
Today 04:55 PM
2011 B9 DPF warning light
Last Post: IKUN
Today 04:51 PM
Yesterday 04:48 PM
Last Post: BrianS
Yesterday 01:58 PM
» Replies: 24
Drop in fuel economy
Last Post: Andhall
Yesterday 09:21 AM
Not able to register
Last Post: Mike
22-01-2025 11:03 PM
Last Post: Matt Haigh
22-01-2025 07:21 PM
M59 rear wheel splay...
21-01-2025 03:27 PM
Last Post: pondweed
21-01-2025 01:21 PM
