Threads: 7
Thanks Received: 11 in 4 posts
Thanks Given: 13
06-11-2020, 05:38 PM
(This post was last modified: 06-11-2020, 05:40 PM by SteveE.)
Wondering if any of you experienced Berlingo peeps can shed any light on a 'beep' type noise when I stop and switch off, well it's actually 4 beeps then a 5th one which sorta fades out...? These seem to be quite gentle beeps not like an alarm and no warning lights as the car is switched off when it happens. (2013 Multispace Plus 1.6 HDi)
Is it anything to be concerned about or is the car just saying bye bye
2013 B9 16HDi Multispace Kyanos Blue (Plan to Camperise)
Threads: 23
Thanks Given: 46
5
The only time mines makes such a noise is when I turn it off with the lights switch still in the on position
The following 1 user says Thank You to Trevor for this post:1 user says Thank You to Trevor for this post
• SteveE
Threads: 7
Thanks Given: 13
(07-11-2020, 08:09 AM)Trevor Wrote: The only time mines makes such a noise is when I turn it off with the lights switch still in the on position
Thanks for the reply Trevor - That's one of the first things I checked.
There's a delay of a couple of seconds after switching off before it sounds, maybe I should just switch off and jump straight out of the car..?
I can't find any reference to it in the handbook and didn't keep the guy's number who I bought it off. Several searches on the Net have revealed just about every alarm bar this one, mind if it is an alarm it's quite faint and doesn't sound 'urgent' if you know what I mean ?
Threads: 23
Thanks Given: 46
5
With luck someone else will see this and give more advice
Threads: 7
Thanks Received: 4 in 4 posts
Thanks Given: 2
11-11-2020, 09:23 PM
(This post was last modified: 11-11-2020, 09:24 PM by smith335.)
Mine does this as well.
very faint beeping,
no idea what it is , maybe some thing shutting down ?
every thing is working fine, so i dont worry about it
B9 (2016) 1.6 HDi Enterprise 75
The following 1 user says Thank You to smith335 for this post:1 user says Thank You to smith335 for this post
• SteveE
Threads: 48
Thanks Given: 4
20
On mine it would be the Pioneer stereo.
Mine has a detatchable front that you're supposed to remove to dissuade crooks from smashing their way into the car and nicking the stereo. And these give off a series of beeps after you switch off the inition in order to remind you to grab the front.
The following 1 user says Thank You to Gadgetman for this post:1 user says Thank You to Gadgetman for this post
• SteveE
Threads: 7
Thanks Given: 13
(11-11-2020, 09:23 PM)smith335 Wrote: Mine does this as well.
very faint beeping,
Opened the bonnet the other day with the engine running then switched off, I could hear the 'beeps' and it does sound as if there's a flap or something closing on the last one, so you're probably right about something shutting down. Everything working fine on mine too..
Threads: 7
Thanks Given: 13
(11-11-2020, 09:36 PM)Gadgetman Wrote: On mine it would be the Pioneer stereo.
Mine just has the standard Radio/CD player - no removable front - I don't think this is the source of the noise, car is running fine so I tend to just switch off and ignore it now..
Cheers
Threads: 22
Thanks Received: 41 in 34 posts
Thanks Given: 21
4
(06-11-2020, 05:38 PM)SteveE Wrote: Wondering if any of you experienced Berlingo peeps can shed any light on a 'beep' type noise when I stop and switch off, well it's actually 4 beeps then a 5th one which sorta fades out...? These seem to be quite gentle beeps not like an alarm and no warning lights as the car is switched off when it happens. (2013 Multispace Plus 1.6 HDi)
My 2012 Enterprise van has done exactly that since day 1.
I think it's electrical or some kind of booster relinquishing it's pressure maybe?
It's never resulted in a problem, so I just figured it was the "bye bye" you suggested!
Various things make strange noises when shutting down (including myself!), so I'd just ignore it and go with the flow.....
Good judgement comes from experience, and experience comes from bad judgement…
2017 Berlingo Multispace Flair 120
2013 C5 Tourer 2.2HDi Excl
Previously:
2012 C5 Tourer 1.6HDi auto
2012 Berlingo Enterprise 1.6HDi Van
2009 C5 Tourer 2.0D
2001 C5 Tourer 2.0D
2001 Range Rover 4.6 Vogue (really!)
The following 1 user says Thank You to Argos69 for this post:1 user says Thank You to Argos69 for this post
• SteveE
Threads: 75
Thanks Given: 223
164
I have always had the same sounds on shut down, it seems to be the ECU closing the egr & inlet doser valve etc and generally just putting things to the closed position ready for a restart.
My old m59 HDi did it too but was a longer electronic tone with staccato breaks in it, like a burst of Morse code.
• SteveE
