08-11-2020, 01:30 PM
Good day all,
I have a definite issue with wheel wobble that I think is related to the steering gear... let me describe...
When coming to a stop I start to get a wheel wobble when I apply brakes, but only at pretty low speeds (say below 10kph or so). The wobble has become worse recently.
I thought is was wheel bearings, so I replaced those. It didn't help. I then replaced the disk rotors, but this didn't actually help much at all.
Then I eventually replaced the whole front steering system (not the steering rack),but changed shocks, springs, push rods, tie rod ends, the whole catastrophe
This tightened the steering up a lot and the car went well for a few months, but the wobble has returned and is getting worse.
When I jack the car up and try to wobble the left wheel there is no play. On the right side there is no play if I wobble the wheel with my hands at 12 and 6 o'clock but there is play when I wobble the wheel with my hands at 3 and 9 o'clock. This tells me that there is play in some steering component somewhere... but why only on the right hand side?
I can't easily see where the play is coming from because, with the wheel on I can't really look, and with the wheel off I don't have enough leverage to wobble the disk enough. The only assistant I have is my 6 year-old daughter, so I can't ask her to wobble it, or tell me what is wobbling.
However, today I noticed that if I use a tyre iron to give me leverage, it looks like the steering gear is moving! I can't really see what's moving, and why it's only moving on the one side... Is it possible that one of the bolts that holds the rack has come loose, thereby causing movement? Could there be something broken inside the rack?
So here's the question: Could the judder be caused by a damaged steering rack, and if so, how much of a job is it to replace the steering rack? I've read through the Haynes manual, but it's not really clear. I've searched You Tube, but there's not much there either.
This tightened the steering up a lot and the car went well for a few months, but the wobble has returned and is getting worse.When I jack the car up and try to wobble the left wheel there is no play. On the right side there is no play if I wobble the wheel with my hands at 12 and 6 o'clock but there is play when I wobble the wheel with my hands at 3 and 9 o'clock. This tells me that there is play in some steering component somewhere... but why only on the right hand side?
