12-11-2020, 11:16 AM
Hi all,
New to the forum,
Just bought a 2006 1.4 petrol berlingo, and there were a few niggles that need sorting.
The last 2 issues are to do with the vent controller dial which is stuck and moves less than a quarter turn. Had a quick look and both wire cables behind are still connected to the unit, can anyone tell me if it is likely to be the actual dial mechanism or do I need to delve deeper under the dash?
The second issue I have is the poor radio connection, I've replaced the antenna mount and cleaned the surface rust from all connections. it does look like water has ran through the cable as the connector on the radio had rusted.
Don't have a manual yet, any help, advice much appreciated.
Cheers all
New to the forum,
Cheers all
