Seatbelts
Hi, does anyone know what the number on the belt reel stands for?
would like to know if I can mount a 96815 085XX where there used to be a 96815085GW.
Suspects (hopes) that the last two letters stand for the color of the belts.
And dosent start the airbag light.
The car is a Berlingo 2008 family multispace
Skickat från min iPhone med Tapatalk
For the correct part numbers, you can check catcar.info
(15-11-2020, 10:13 AM)cancunia Wrote:  For the correct part numbers, you can check catcar.info
When I look at their site,I can't see the oem numbers... Do you know where I can find them?[Image: 7d924ef727f8527bf199286fd890bf62.jpg]
[Image: 31cb1e24028f7cfeab7cc989001a318b.jpg]
The pictures can be viewed in the webveesion of the forum but not in tapatalk.
What numbers do you get from Catcar?
See picture, it doesn't matter if the color is different.
Just need it to work with the other airbagstuff.
The part number you have marked in your picture shows the following in a google search for 'citroen 8975y0'
https://www.proxyparts.com/car-parts-sto...d/9091898/
You can see the long part number in the result. My guess is that the part numbers in catcar are for a later version of the seat belt reel. Hopefully some more searching like this will enable a cross reference that will be of use.
  • pwlind
Thanks for the help
07-04-2026 04:17 PM
Apple Carplay
02-04-2026 01:26 PM
Last Post: Transmit
02-04-2026 11:21 AM
