[Steering & Suspension] Vibration in steering wheel when I'm turning slowly left or right.
Hi folks, im new to this forum, I have just recently bought a 2014 berlingo 1.6 hdi. I was very happy with the van at first, but after about 2 weeks, i started to feel vibration in steering wheel when turning left or right, when im turning into roundabout or parking, iv brought it back to the garage where i bought it, and they have changed the power steering pump and the rack, but its still the same, I've read some of the forums here about recalibrating the steering and driving for a few days, but i haven't seen any change. I'm just looking to know has anyone else experienced this, i would be grateful for any info on what to do, as any garage i've spoken to don't seem to know. TIA
Threads: 123
Thanks Given: 250
34
Welcome to the forum.
Did the garage check the wheel bearings?
How many miles /KM has the van done?
Cancunia thanks for your reply, wheels bearings were checked also there fine, van has 154000 km, van is in good nick..
Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
Strut top bearings?
Jack the front of the car up at both sides so there is no weight on the front wheels, is the vibration still there when turning the steering?
Jj9 i will try this today, ill let you know how it goes, thanks for your reply...
Jj9 iv tried doing what you said, but hasnt made a difference, still vibration through the steering wheel when turning at low speeds,
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
21-11-2020, 03:52 PM
(This post was last modified: 21-11-2020, 03:53 PM by brodfather11.)
I would have thought a CV joint worn or breaking up ?
or mud flap rubbing on wheel when near full lock which you would'nt get at high speed.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Brodfather11, thanks for your reply, no none of the above, are the problem, i cant seem to figure it out. Really baffled ?
Threads: 8
Thanks Given: 305
37
21-11-2020, 07:35 PM
(This post was last modified: 21-11-2020, 07:36 PM by jj9.)
As brodfather mentioned a worn CV joint can cause a knocking which often translates to a vibration, but if you have the vibration when the front is jacked up and the wheels aren't turning I would be inclined to look elsewhere first, that said you never can rule out anything when trying to find faults like this.
I know you said you had tried recalibrating the steering but you could give it another go... https://www.youtube.com/watch?v=LzzzZjX-51k
Take a look at the Universal Joint that connects the steering column to the rack beside the bulkhead, these can become dry and give tight notchy steering, a spray of lubrication & coat of grease will keep the joint happy.
I would try feeling for the fault, with the wheels off the ground place your fingers on components as the steering is turned and see if you can feel the vibration, the coil springs, the lower ball joint, the track rod end / steering rod from the rack, the ball joint ends of the anti roll bar drop links.
The power steering pump is controlled with electronics, could be something to do with that lot?
Threads: 75
Thanks Given: 223
164
22-11-2020, 06:50 AM
(This post was last modified: 22-11-2020, 06:53 AM by Sol.)
Also worth checking the coil springs aren't rotating when the steering turns, independently of the strut top. I've had this before and the spring had jumped the little detent bump at the ends so it was turning in the spring cup. It made the steering wheel feel like it was juddering very finely when turning.
I suspect the very tip of the coil had snapped off so the spring started rotating. Wasn't so noticeable on the road. Just when parking. Every now and then it gave a noise as it passed the detent bump and dropped back into the groove (very faint twang from inside)
Have you turned lock to lock smoothly while parked with the windows both down to see if you can hear anything?
Strut Top Mounts
Today 07:58 PM
Yesterday 09:30 PM
Yesterday 09:27 PM
Rear seat belt breakage
Yesterday 04:13 PM
removing front strut
13-09-2026 06:10 PM
12-09-2026 05:49 AM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
29-08-2026 08:39 PM
